Yesterday clean radiator with tatri remove thermostat pour tatri solution into radiator run car for almost 20min amazing results for rust install thermostat put coolant now ride is ready for summer.
I used any chines coolant easily available in market for 200 rupes per litter just put it in deep freezer for a night and it does not freez Baki 1000rupe litter b Hain but they work same tested again and againI buy name veesli
Thermostat already install tha just saaf Kia Pani garam kr Ka aos m dala kahin stuck Tu Nia hu rha safia ki wd40 spray kr Ka aosko again laga dia buy 2 litter coolant 50 rupee tatri and 300 rupee wd40 12mm socket will use distributor open Krna SA phela marker SA nishan laga lein taka timing disturb na huYa car ko top gear m dalin rotate front wheel jub drill mark timing pully Ka cover Ka samana ajaye AOS wakt TDC Hu GA aab distributor utar lain
Yes bro Hu jata ha but bolt unscrew Krna thora tough hota ha due to conjested space
I recenly bought a cuore and it has a problem of startup in morning.. it starts in 4 5 selfs.. battery is ok.. what could be the problem?
Check battery voltage when cold . Starter could be issue too . Wrong timing . Faulty fuel pump . Faulty carburettor etc . You need to rule out mechanical and electrical issues
If after start up if it start on half self whole day then it should normal for carby cars cold start if after start they took 4 to 5 self then follow @wasf
Tappet point battery coil fuel pump is ok.. mechanic says its a problem with auto choke and it cant be repaired.. carb should be replaced. Another mechanic told me it cant be due to auto choke as car which does not have auto choke also start in first self in morning. My car increases rpm in morning but the lid that open and close which is underneat the airfilter has a little play in its spring
Auto choke is not rocket science my cell 03004495201 WhatsApp me detail
I had same issue... Plugs changed.. Now ok
Can anybody please guide how much would be the total cost of complete engine overhaul for cuore 2006 manual. Thanks.
The last time I checked three months ago, it was 35,000 for complete overhaul. I asked from Tariq Rd. Karachi.
Dear sir ye kitne price ka hy
You are calling a person, who was here 5 years ago..
Hi!
I need get a minor paint job done on my car. Cuore 2004, navy blue color.What would be the price? Paint got off from the bumper, around 8 by 4 inches area
Can i use BPR5ES spark plugs for Cuore 2008 Automatic
