Water Supply Line from Pump to Water Tank at Roof گھر روز روز نہیں بنتے
Whenever laying the pipelines, always prefer to send independent pipeline from pump till water tank at roof top. To reduce the personal efforts , sanitary guys usually prefer to connect pump with common ring line in the house which mean e.g. if you open the tap in kitchen or washroom, you will get the warm water coming out of bore via pump. This practice is wrong. In this way, pressure from outlet of pump exerts extra load on fittings and joints, hence chances of joints and fittings failures increased.
Always advise sanitary guys to lay an separate pipe from pump to water tank at roof top.
A detailed analysis on what type of pipes shall be used, will be furnished in next post.
