phir.
valve body remove karo
tcc stroking valve ki sleeve inspect karo, agar valve jammed hai to brush se polish karo bore ko
spring check karo.
wapis fit karo
repack karo
retest karo
agar nahi masla sudhraa
to transmission ka running pressure check karlo ke pressure drop nahi horaha, agar horaha hai to variator assembly khol ke inspect karlo, sahi hai to oil pump control valve ki sleeve aur piston check karlo, agar worn hai to replace karo pump unit ko. - ye check vacuum pump se hosakte hain thori lexan plates ki fankaari ke saath.
taqreeban USD 3000/- ke parts aainge.
iss ke baad - toyota se brand new torque converter purchase karke install karlo
@Xulfiqar Bhai Pls Inspect the valve from the attached video , What do you think of these? Does they seems to be jammed? I didnt brushed them only cleaned them , And dipped in fresh fluid and fit back. They seemed like Working smooth then before.
Update on jerk : There is some Differnce compared to before , The application of tcc at 50kmh is now almost gone But the de application during de acceleration Is As great as before.
Also Working on to get the Tcu Update from TSB.
