Not really . Going in to install 2.5" drop spindle's , Tie rod end's , Long throw upper and lower ball joint's , bearing's , eccentric camber nut's if needed Today by khalid sb , brake's will also be adjusted and overhauled . Brake cylinder's are also on their way . Engine will be overhauled with new piston cylinder's , oil cooler , original Alternator , main bearing's , ring's , valves ,valve guides etc etc , upon opening will see what's gonna happen , some machining probably . Will be done this month but waiting for the CURIL T sealent to arrive from the Uk first week august so will be closing the engine after it arrives , some other engine part's are also on the way Exhaust valve's etc , got a new air cleaner aftermarket style from a vw performance shop in the uk which was much needed , would advise new vw guy's to use either Curil T or K2 . But the local Curil also work's but i won't risk my new set of piston/cylinder's and everything else with it . Body work and paint is left after this , that too will be started in about a month's time as the guy who's gonna do it has a Vw he's working on right now but will be done around in a month and a half then off to bodywork . Then my Air suspension for the front will also be on the way , hoping to hook it up in the coming 4-6 month's because will be doing that after the car get's painted along with the wiring phase probably. Will update BEFORE/AFTER pictures today of the 2.5" Lowering (Stage-1) . Also found a guy for deepening the vw wheel's so will be hitting him up this month to drop my wheel's off for deepening and widening , the process is called banding but i'm not sure if these guy's do the banding procedure , will confirm soon . I'm looking for 7 to 8 inch Width for these originak steelies . Finger's crossed. Also scored 165's (tires) for the front so that the fender's don't rub the tire's after i lower my car so gonna get them too sometime soon. Also scored 1965 vw original wheel's (Non slotted ones) , put them on yesterday , bought a rivet kit for them also just have to get the Dome hubcaps now and the wheel's will be complete .
