Dear @Xulfiqar
Today visited the punjab car ac and talked to the mechanic about the problem. He says to take one chance he steam wash the condenser and radiator and top-up the compressor oil. After this the car ac on time and cooling improved but the main issue remains i.e. car ac stop working at high rpm.
Visited couple of shops for price quotation
1. Coolsun quoted 26k for 2006 model clutch compressor with radiator with 4 month warranty
Punjab ac quoted..75k for new system
35 for used one.
Bashir car ac quoted 20 for clutch compressor only with fitting.
After all i visited bilal ganj lahore
There are three types of compressor solutions
2006 model xli clutch compressor with price 11.5k pkr with warranty of 15 days
2010 model sensor compressor costs 3.5k pkr with only check warranty
2015-2016 model sensor compressor which is of improved designed as compare to last model and they quoted 10k for that model but gives warranty of only one day. Shopkeeper said this compressor is the improved version of last 2009 - 2014 model and it will do best.
Need suggestions
Which solution will be good.
I am hesitated of using clutch compressor because it decreases the fuel efficiency due to increased load of clutch ac on engine.
I am bit interested with option 3 i.e. to give a try to 2015- 2016 compressor with sensor.
