When all load is put it drop rpm while driving.Electrican said he will add extra vaccum for this
I have ferio civic just to add
ELD pin is present in every ecu.
there is no check light for ELD
PKDM and canada models don't have eld.
This is connector A and you can see no eld pin. It should be A30
Its not neccesary that you get the ecu of your engine as it can be possible that the wiring is connected properly. On petrol my car also don't have any cel whereas my engine is D15z6 and my ecu is p2m which is for PKDM D16Y8. You should take picture from the side of the ecu where sticker is there.
i'm talking about Ecu. Ecu supports it.
This highlighted part is called eld in fuse box
If you knew any one in karachi tell me i will go there for check.
sorry i'm from lahore.
Have you also replaced fuse box when changing wiring? Because the stock fuse box don't have eld
No I am asking is this highlighted part is eld .??
I didnt change fusebox
@Hassan1991
Is this marked area is eld in fusebox
Yes
Maybe previously your fuse box is changed. Because JDM fuse boxes has eld unit
Should i check this by removing it if wire is connected to it. Or by replacing it
Yea it is jdm version. it's ferio even though i have different console too . With digital ac climate control
This ecu is for D13b engine and Most probably it's a obd0 ecu.
@hassan1991
I cannot find pinout for your ecu.
Now what i have to do . As to correct that rpm thing or have to drive lile this.
