Thanks for advice.
i would use shell 5w-30 or 0w-20
+1 for zic as long as you are buying the original product
@Xulfiqar sir can I use LPG gas cylinder for Argon gas? I'm arrange TiG welding equipments. Already got welder, torch and filler rod. Having difficulty to find argon gas in Lahore.
@Xulfiqar I checked the resistance of spark plug wires in my Mehran 2010 carburetor, they are ultima aftermarket, i've been using them for 2 years & 8 thousand kilometers. Three wires going from distributor to plugs are ranging 8.2k ohms and wire from distributor to ignition coil is 4.6k ohms. What is the standard range for resistance in wires, is it fine or does it needs change. ?Regards !
Assalam O Alikum Brothers, I want to tell u people that I got petrol from a PSO pump in this bottle and after filling my pressure washer's fuel tank till its neck,this much petrol remained in bottle,I mistakenly placed it under direct sunlight for about 4 hours !! its colour changed from pure light green(which normally its colour is when u get it from the pump) to dark green and this black residue was settled down at the bottom of bottle;When i lightly shaken the bottle, the particles of residue came up ,those can be seen in the pics attaced !! I want u people to conduct the same experiment with a very small amount of petrol from any of ur nearst pump to confirm that either all of us are getting this poor fuel or only pump i got fuel from is having that poor fuel;and can someone tell what kind of residue is this???
Can I put more fan blades(5 par wala in desi trm) in Cultus fan?
Incase if motor is burnt too. Rewinding possible?
How much fan blade alone and fan motor of Cultus will cost in Karachi?
@Xulfiqar i have a suggestion for you .If u write a book titled : FAQs about vehicles in Pakistan and their answers .It will have two advantages 1. Your knowledge will be documented.2. Anyone not having acess to internet will also be benefited.Fruit for thought
Its easy actually just copy paste of this thread
waiting for someone's reply about this issue !!
Bro in Islamabad, fuel pumps stopped giving Petrol/diesel in bottles a long time ago.
bro it was cap was on thats why it didn't evaporate and I'm not mainly reffering to its colour,I'm telling about the impurities(black residue) seen in the bottle!!
brother when i got fuel it was clear like hell !! but after some sunshine that residue came! if these impurities were supposed to be from the tank then they were must be present at the time of fuel being filled in the bottle...
@Xulfiqar
I am having issue with the fuel trim. It is normal on idle. However when I increase rpm the fuel trim becomes negative. Car is Accord CL9
At idle
Increasing rpm
At 2000 rpm
At 3000 rpm
Have checked various things. Fuel pressure is 50psi. Fuel injectors are not leaking and are all balanced. Exhaust is not clogged. The trim does not improve much when blowby is stopped going into the intake. Spark plugs look fine.
What could be the issue.
