Perhaps check the pad thickness? Even that is overkill every 6k miles. Lubricate pins/slider points? Perhaps.
Just cleaning
Every 10K, but I got it done at 20K kms
So they clean the pads and the shims, and clean and lubricate the anti-rattle clips, touch points and the slide pins. That is a good job if done properly.
Don't know, have never observed this so closely as I don't know anything about brakes, so leave this up to them, don't have any issues since 2005.
Fair enough. Brakes are actually quite easy to work on to ensure proper and safe operation, but as long as this sort of work is done, it is good no matter who does it.
Yup, I change and service brakes myself. Usually a simple step by step process following any tutorial.
Real avg of my Grande. Full tank to full tank method. All local drive, Rawalpindi, Islamabad.
Some recent snaps
Some beauty products bought
How is Ultimate Polish different from Ultimate Liquid Wax? Please educate.
There is a fundamental difference between a polish and a wax. Polishes are generally abrasive, some less some more, but waxes, except cleaner wax, are non abrasive.
Hi can you please give me the contact number of thre vendor. i want to get software of my grande 2018 infotainment updated.
Please check your user manual for infotainment. Contact number is given there, they will give you contact number for the tech in your area or call dealership for his number. For Rawalpindi, Islamabad Rizwan: 03007443554 check if he is still working with them.
Shah Mahmood..tecno Lahore. Dealership can help u as well
+923008409488
Tell me your current build number...i will confirm u if u should expect an update or not..
