Friends u have to tell me that baleno back windows and not totally closedOne of my friend told me that its originally like this.
Yes, it's originally like this. However, I've seen some Baleno's whose rear windows open fully.
I open the sheets and start lubricating the window panel.after a while mine friend came a ask that its its originally like this
Now 2 things in which i need suggestion1. Which engine oil suitable for summers as in my area temperature touch 45 C normally.2. Did anyone have baleno user manual then pls share
If your engine is in good condition then use any well reputed company's 10W40 API SL emgine oil. I am using ZIC X7000 10W40 API SL synthetSL oil in my efi cultus. It has same scale down version of Baleno efi engine with flat tappets.
If engine is in good condition, 10W-40 is good.Also, I have the full service manual for Baleno. I will WhatsApp it to you in some time.
Dear u already have my number kindly pls WhatsApp me
And engine is in alhamdolellah excellent condition.and also tell me the running hours after i change oil
Zic X7000 price and after how many running hours u change synthetic.as some people says synthetic oil recommended for some extra running hours
I paid Rs 2250 for 4 liters pack. And change it after 4000 kms
I still remaining some KMs after that i change then share results
Did anyone use kixx brand oil.what is its feedback
Another thing wind shield water spray is not working when i check its voltage.they are ok so removed the tank and pump.again check with direct on battery pump not running so now going to open the pump may i do its maintenance
Pump motor is showing OL its mean problem in motorGoing to open motor but its sealed motor lets see what happened
One cable disconnected
Results
Dear did anyone know about AC filter in baleno
There's no AC filter in baleno
Can we installed by any modification
Today open alto AC(a friend car) see the condition of evaporator.Uploading...
