Well then, the engineer in me tells me that mechanical values (especially lubrication) are always tolerances. YES, they ARE max and min. The engine is designed to function with a certain oil consumption in mind. Infact, if you adequately drain, with 4.2l you will be sitting just ever so slightly below the MAX mark. I can go into much much more detail, but it would be overkill.
