I have a City 2002 (SX8), its crankshaft just broke.I am located in Karachi, please tell me what my options are? A new engine or should I get my crankshaft replaced and from where?
Lawernce road or shershah
Maybe I wasn't clear enough. I want to know which engine will be a bolt-on replacement if I go for a swap and will the engine be just as reliable with a new crankshaft. Most importantly any good mechanics you'd recommend?
New / used crankshaft is very conveniently available from parts / scrap yards.
changing engine means edorsement of engine number in registration book.
by the how did you managed to stress engine so much that Crankshaft is damaged ? please share
New roads paved behind my house, I was redlining it.What will be the cost of a new crankshaft approximately? And should I get it replaced from any mechanic or is it not a straight forward task.P.s. endorsement of engine number not such a big issue, I do not care about resale. Tell me whats the best option.
if you are located in RWP / ISB contact @rajaatta if you are in Lahore contact Obama car & truck centre 0321 4106898 in Tipu Block Lahoreif you are in Karachi contact jamil auto 0300 223 7538
only after engine disassembly & inspection the workshop can guide you to a economical solution.
Thank you. I will get a quote from jamil auto near quaid e azam mazaar i believe
yes, at shah rae quaideen
Monday inshAllah. 20 hazaar k andar hojaega? Muje shoes b khareedne hai eid k.
Honda City parts are avilable in abundance without engine removed & inspection of crank / pistons / connecting rods nobody can give you estimate.
EID k Shoes ?? Bata / Service zindabad.
Hunh mai te bata he lesa
with currency exchange rate in projectile situation imagine the new parts price and the scarp yards prices rocketting too.
Yes I just spend 30 thousand on new tyres for this car a week ago and now this happened. But will opt for a long term solution rather than a jhugaar.
Bhai camshaft or crankshaft?Have you inspected it your self or some mechanic has diagnosed
Crankshaft bro, mechanic ne he diagnose kiya hai. Alternator powersteering b nai chalraha due to the belt not spinning anymore, engine mai loud ticking noise b arai hai.
Bad luck bro.As it was crossing the red line.Seems compression is good.You should opt for a lower end overhaul.And after opening the lower end if only crank and beArings has to be replaced than go for it.And do try shafiq more market for finding crank,as they have mila jula saman kabli/civilian mixed.It will be cheaper to source from there
Thank you, will go this monday. Koi b idea hai kitne tak ka jurmana hai?
Jurmana isi engine pe shyd 20-25k max and new assembly will cost 35-40k.
@Salmaanawan whats the update sir ?
It seems like someone was trying to rip my little brother off by saying that the crankshaft broke, yesterday i towed the car and took it to a mechanic I knew, he checked everything and found out that the main pulley was broken and its teeth had been smoothed out after 17 years of abuse. I bought a kaabli pulley for 4500 and got it installed for 1000. The car works fine now alhamdulillah.
