Plus glide induces water spots and dries wierdly.
Yar actually the thing is I am a proud owner of Graphite grey and i am not being able to clean my car daily so I have hired someone to do that for me. I get him a normal spray (solely water) and good MF towels to wipe it up for me. So i was just wondering should I get the ECH20 to aid better cleaning or should stick to the way its being done currently?
If u want to avoid swirls..the use ech20 but m sure till now ur paint will have lot of swirls .before spending on ech20..get ur car polished first to get flawless finish.
salman sir any product to remove the water marks inside the bonnet and other parts of body as i tried many polish and shampoo but they are of no use.
Bro water spots kay liye nanoskin spot remover to ata hai but i found if not very effective. Polishing with DA helps. Once done..u need to wax ur car under shade and akways wash under shade as well. Never let water dry on surface..and dry using waffle weave towel ASAP.
Have you tried polishing compound?
Use nanoskin compolish...easy on paint and arms.. nanoskin homerun for bonet inner..it will make ur bonet..door hinges and engine bay almost to day1 condition
Is it correct that glass coating is done after removing original clear coat of vehicle?
No that's not correct at all @hashimkhalil27
Na bhai..who told u this? ...it is done by polishing to a perfect finish.
If clear coat is removed.then..sab khatam bechari car ka
Toyota ravi guy lol. I was also not convinced by his saying. Ceramic coating is good or glass coating?
That guy...
Ceramic... depends on brands as well
no but now i will surely try the compound as never got the idea of using it inside the bonnet.
so i have to use nanoskin spot remover firstly to remove spot and then nano homerun for perfect finish ? and nanoskin compolish can also be used solo instead of both above?. thankyou
For sale one of the best quick detailers on the market. Available in 100ml concentrates, which will make 1 litre of quick detailer. Water based formula perfect for use on literally every surface of the car including paint, glass, rims, tyres, interiors etc.
Homerun is for inner side of bonet with 1:15 dilution. Don't use it on outer surface of car.
price?
@abuzerkhan inboxed u!
Details by Babar
@hammad225 how is pressure washer going. i am hunting for one as well
why pioneer and which model and how much did it cost you.
You suggestion will help a lot.
You can sms whatsapp me on 03335268628
Thanks
