AOA Pakwheelers!
I have a Mitsubishi Mirage 2012 with 80000km mileage. I came across a very strange problem just recently. The car starts, drive is good and smooth, but after a while (10-15mins) it stalls and shutdown (mostly happens on turns/slow speeds). If I try to start again, the engine cranks but it doesn't start until I press the gas pedal, after which it again stalls and shutdown. If I leave it for 3-4 mins, it starts again, manages to run fine for another 10-15mins and again shutsdown. Once it stalls and shutsdown, the headlights n dash lights remain on.
Few points to consider:
1) There's no check engine light (will it give error codes if I connect it to a computer)?
2) The catalytic converter, Throttle body, Fuel pump have been recently cleaned.
3) The battery, oil, air filter is new.
I read about it on the internet but came across several problems , Idle air control valve, weak spark plugs, failing fuel pump etc.
I want to ask if anyone has ever come across a similar problem? The thing is I am in Abbottabad, can't trust the local workshops, and I can't travel to Rwp cz this car doesn't run for more than 15 mins.
