Aoa... Lately i’ve experenced an issue in my vario 2007 that while its crosses 60 km/h, the speed decreases to approx 40 kph instead of increasing (on a level road with increase in rpm and constant throttle) as if it were breaking... after a jerk the speed goes high to 80kph with decrease in rpm... This has happened 3 times... tramission oil level and color is ok and performance of all other gears are ok
Seems like problem of cvt. Rest gurus can guide you better
Thanku, but can it be repaired or do i have to replace it
It cant be repaired. You have to replace it. But before going for its replacement try to rule out any other issue. Like clean or replace fuel filter, fuel pump, plugs, air filter etc. Because cvt replacement is very costly.
have u checked coils and spark plugs. check them properly
If the rpm keeps going up but car slows down as u said it has to be gear issue
Gear is around 12 to 18k replace it.
