XE 1998
EE 100
CNG
i own this car from last 6 years
Clutch worn out after every few months.......even sometimes after few days
This is how the problem started that.....gear becomes hard, clutch peddle become soft and down.....and clutch release the gear at the very beginning..
mostly i observed this problem at the heighted place at low speed.....
this is the repeated problem....even i have done these things.....in last six years
Installed Clutch Pressure new Japanese set: 1 time
Installed new clutch plates 4 times
Fly wheel clutch pressure plate set (kabli) 2 times
Installed Gear (pulled from Japaneses engine) once
have replaced clutch master cylinder....few months ago...
but the problem remain same which em facing:-
most of the times its happening when the engine becomes hot......and at heighted and low speed
sometimes clutch unable to engage the gear ebven after pressing the peddle.
engine is rebuild and perfect and have good pickup and provide speed 120 km/h easily at cng at long run
Suggestions and Solutions awaited plz...
