Mehran 2012 non-EFI.
Got 26kg LPG filled in two CNG cylinders. The jeep has covered 205kms till now with ac most of the times. The jeep has been standing idle with ac on for more than an hour. No setting has been done yet.
Sent from my GT-I9500 using PW Forums mobile app
Haroon. Where are you getting your car filled? And is there any alteration done to the filling nozzle of the car on CNG setup?
Thanks.
I get it filled from sabzazar, where i live. Yes, some alteration was done to the nozzle
Are there dedicated LPG filling stations in Lahore from where you guys get it filled or regular LPG retailers fill your cylinders?
Regular LPG retailers
Means kisi bi time filling kartay huay cylinder blast honay ka pura chance hayVery unsafe
not at all. cause cng operates at 200 bars while lpg pressure is 4-5 bars only.
Sent from my TCL A909 using Tapatalk 2
Anyone from Islamabad has filled his car with Lpg instead of cng. Kindly share the rate, place of refill and mileage.
Sent from my G1 using Tapatalk
Kon kehta hy?
Kindly clear this misunderstanding. CNG cylinders are tested for high pressures exceeding 300 bars. LPG is a low pressure gas. Reallllyyyy low. Using a CNG cylinder for LPG makes it highly safe rather than dangerous.
went to two mechanics for lpg conversion of cng kit they told it is possible but lpg is very much harmful for valves coz its burning is higher than petrol and cng. is it really harmful ???
Lpg has an octane rating of 110. Normal petrol is like 87 in Pakistan. Usually you change the injectors to accommodate lpg. It won't make an issue, depends on the engine.
Sent from my HTC One_M8 using Tapatalk
If ur car gives u 8km on per liter Petrol then average of L.P.G will b 20km per KG and On CNG 25km per KG.
u will fell no smell while driving
it doesn't stop working injectors ? like in cng injectors are by passed ??
Not all engines are made to run on alternate fuels, some needs their Injectors changed. I am sure PKDM cars have no problem with that.
most road side mechanics think that high octane number causes valve damage, it is totally opposite to that, using fuel with lower octane number than recommended causes damage to components in engine due to pre-detonation and not vice verca.
if somebody knows really capable person for converting a cng kit into lpg kit for liana car in Faisalabad ???
what is current price of LPG?
100 rs per kg in lahore
Sent from my QMobile A65 using PW Forums mobile app
