Is there any way to convert 660cc 4wd car into 2wd? So that it becomes more fuel efficient. I m in izlamabad so pls help if you can give a tip
Remove 4wd drive shaft. Cover hole. Done.
what average you are getting from 4wd? and what are you expecting from 2wd?
I am getting around 14 in Isb city. But my cousins same 2WD car is doing 18km in city.
which car you have?
Subaru Stella Coustom 2007.
remember two same cars with same spec will not give you the same average
Nope brother mine is COUSTOM version and second one is simple model and 2WD as well. So thats the difference.
remove 4wd shaft then try.
How to do it. Dont know about it. Can someone please guide.
I remember a pakwheeler removed drive shaft.found no diff.n then had a prob searching for shaft as he gv away original one .he wanted to install bk.14 is a decent avg live with it.jdm altos do that much
Back internal view of car.
I remember my mechanic removed this shaft from Premio.
@vaqas can u please tell me are you from ISB or RwP??? If soo give me number of your mechanic. I will contact him.
Riaz +92 302 5006176. Tell him Waqas gave you his no.
Thanks.
Btw he's in rwp.
Ok I will contact him tommorow. Inshallah. Thanks Again Brother.
Subaru stella have 4 cylinder engine i think. Fuel thirsty engine.
I have diahatsu mira e.s 2012 4wd but the shafts was already removed but am not happy with the milage it gives 14 per kilometers in the city without ac. I am facing this problem if anybody can help me out regards,
