Can anybody tell mere pas coure 2008 hai uska steering bilkul soft tha front axle or suspension ka kam karwaya hai us k bad kafi hard hogaya hai koi solution bata sakta hai ?
no worries...sir kuch din mein theek ho jaye ga...
Chimtay kay ball joint aka goli to press nai karwai?
Uss ne kaam karwaya hai
Ball joints,Tie rodsRack ends
Sabb hammer press howay honge, axle rebuilding ke saath.
Haha true
Hello DaniyalAp nay plug wires or coil mangwa le meri gari ki?Cuore Efi Automatic
Nai sir sab new dala hai repair nai karwaya
Nai suspension ..or axle ka kam karaya hai axle b new hai
Rebuild nai hai new lagwaye hain
Naheen, I thought apne replace krwalin. Jis din apne ana ho usay ek din pehle bta dein I'll bring them.
Kya kya naya dala hai and keemat btayen, hum uskay accordingly guide kardeingay.
Axle new dala hai or tie rod new dalay hain
why dont you take it back to that shop. are the axles packed correctly? - are the tie rods grease zerk type? - if yes - did mechanic actually pump grease in them?
were ball joints worked on? - were front struts removed and worked on? - are strut bearings good?
Thanks for info
Sir there is no sound in axles and no vibration or any other problem seems infact i'm enjoying driving now than before just steering got hard.
This is because mechanic has messed with the ball joint of control arm or have used Chinese tie rod... They are really hard and make the steering hard.
Are these dry? Or mechanics forget to grease them?
Usually replacements have zerks in them
