Yup 100,000 km is minimum........if breaking in is done properly then 200,000 km is nothing
I bought OHC assuming it was kabli... I took my mechanic alongwith and he selected the Engine ... Well , DOHC was out of the question because it needed lots of flirting esp changed wiring.. The Engine is in standard position according to mechanic......... God knows
Anyhow today the mechanic changed : Ignition module, distributor and fuel supply wiring...and guess what... the issue persists ...
One more thing i want to ask is........... do we have best AC performance in daewoo ? if yes how.. mine works as a cooling fan at the moment...
Bhai @Mirza967 ,suggested to check pickup coil,spark plug cables,and ignition switch.Did he tested those as well??It is a current problem as @Mirza967 has suggested.Waisay who is your mechanic?Mirza Bhai also lived in isb/rwp,he can also suggest you to good mechanic
First sort out this issue,than you can go to fellow pw member @dani_kk he is running an excellent ac workshop.Inshallah you will not be disappointed.
I m also a bit skeptical about Daewoo ac. ....it's geniune ac w used r12 gas which was Soo cold that person started nauseous........but when Desi uatad filled r134a.....it didn't worked properly....for that u have to change multiflow condenser .....change the mineral oil of system to PAG and change orifice tube to r134 TXV......then it works good on r134
Bro the plugs, wires and current issues were things he checked 1st ( I forgot to mention these things in my post)
My mechanic is Shahbaz.... at sanam chowk, lethrar road.... he has been my mechanic since 2015...
Check pick up coil and clean the ECU grip and pin out with electric contact cleaner
@Mirza967 .Bhai do you also changed your ecu aka computer along with the engine you bought??Where is the ecu of your old engine?Can you please check voltage output of your alternator/generator?Is your alternator is old or it came with the afghani engine you bought?From where did you bought engine?Mithu Khan or haji maqsood?
Don't worry, you can visit me for excellent ac services...
So things I need to change are :Condenser Mineral OilOrifiace Tube
SIr can you tell me how much shall it cost ?
@abiiktk Have your missing problem sorted out?
THANK GOD ..Yes
Share details please.Ac ka Kaam man karwa rahay hain?
Actually mechanic k pas khari thi,,,, he said kabli fuel pump dalny sy theek hui hy,,,, es sy pehle wo 4 pumps change kr chuka tha
AC ka kam karne sy pehle gari ko air tight aur sound proof krwana hy,,,
I overhauled engine sir.....not bought any assembly.....they were not up to my standard..... generator I found was of delco Ramy ...which I found at very low cost......it's generic GM Delco Ramy 65 ampere alternator
Yup especially that insulation of firewall......it's creates a huge difference..... remove it and repair it from some mochi if torn......and install it....it creates a huge difference
Bhai you are our hero,since you are the only one who genuinely love daewoo like me,who I always look up to.
The question was directed towards @abiiktk and you were tagged for your professional opinion.I can't even think of surpassing you,in troubleshooting.
