Hello there, I have recently purchased a Daihatsu Sonica 2007 model so far drive is good, this is my first 660CC Japanese small car, seems like im loving it apart from this one here in pakistan i also have Honda city 2005 model...loved that too...
alright lets come to the main problem that im facing right now is its ABS is definitely not working as i have had driven alot more European car i do know what does this ABS stand for.....so in a nutshell, every i pull the brakes, my car's tyres get "LOCKED" means it skids..i have been to Iqbal Piyara at Chowburgi, Lahore, he has diagnosed that ABS is not working...firstly the guy was like okay lemme Reset it it might start working....and the Error was removed but on computer i saw my self that "FL Solenoid not working/Short wire circuit and RL Solenoid not working/Short Wire circuit" The guy goes its Front wheels sensors are not working....those need to repair i said fine...guy took a while and got back saying these are fine, lets put these in and he did after restting it, the same issue was coming on computer he called his senior called "Irfan" he checked it and goes "ABS UNIT" itself is faulty, you need to buy a new one from bilalgunj....
So now the issue is, is there any other way i can get it checked whether its a Unit or wiring that is causing the problem...?
I would appreciate your time and suggestions..
Regards
