Hi I owned a new daihatsu move 2015 model i m third owner. I just changed his engine oil 5w 40 kixxAfter changing car fuel avg showing low at 10.5kmBut before changing it was minimum 17km on dirty engine oil I want to discuss what is the reason of mileage getting low after changing oil and air firter
Why 10w40? And how much quantity did u put in?
Which oil brand u r using?.And this may happen if ur car computer ran out of program. Bcz in these car mixture of air and petrol is mixed according to petrol.As ur car is runing high on petrol so u have to first check the silencer of car if its is black or not?Or any type of smell that causes to get tears in ur eye then this will be fault in ur computer progamming. Visit any nearest car computer mechanic he will reset ur car computer and it will be fine.
10w-40 is too thick for your car get 5w-30 (liqui moly) or check your car manual for exact grade. Most jdms works fine with either 0w-20 or 5w-30. I am using 5w-30 for my 2014 mira and getting 18.7km/l with ac.
mileage depends upon a lot of factorsthe engine oil should either be 0w20 or 5w30 as this is what manual recommendssecondly oil and air filters also play an important role in mileageand petrol quality too
which oil and air filters you used?
10w-40 is to thick bro use 0w-20 or 30
Sorry 5w 40
Can any body tell me why my car lessened engine oil.after use of W5 30 grade engine oil. I am.much worry about it
upto 500 to 750 ml engine oil reduction at 5000 km is normal.
This topic was automatically closed after 60 minutes. New replies are no longer allowed.
