Instead of using LPG in CNG cylinder, I am planning to put a Lovato LPG kit (Italian) in my car and will be putting up parallel steel fuel line with a standard LPG cylinder which is provided by LPG companies such as FON, POL or any other.
Benefits of using that setup is that I can get the LPG at a cost of Rs. 1,530 per 11.8Kg cylinder, about 11.2-11.4KG gas could be used by the car using this setup and it will cost around Rs. 129 per KG which is still cheaper than the price which we are getting from the LPG vendors who are looting us. I already have a cylinder and the kit setup alongwith fuel line will cost around 4K.
If someone has an experience with Lovato kit then please shed some light on it.
One disadvantage which I have observed in using CNG kit with LPG is that, LPG ruins the diaphragm, piston of KIT and it starts to leak, further the filling valve of car also get damaged due to low temperature of LPG. Using a proper LPG kit will remove these maintenance issues.
