i would like to share with you last Easyconnected English version for WINCE
[Mod Edit] EasyConnected(ENG) - Screen Mirroring / Mirror-Link Windows CE / Smartphone Android (Give path to multiple GPS Apps ) Android screen Mirroring on WINCE/ CASKA City Aspire In-Dash Navigation System / any Wince)
1 .It allows screen mirroring from Android to Windows CE unit, through USB cable.
2. It allows to give path/ Select between different GPS Software present on your memory card (basically for those WINCE devices which don't allow to change the path to Navigation Software)
It is very very simple
- Only You have to download from following link
https://drive.google.com/file/d/1U83qdv44oMsHNCXfH3kpujCS5HPnd5PU/view?usp=sharing
https://drive.google.com/file/d/1W2bR0ADIi7enymjpGAT0ZQZjMzXlw_93/view?usp=sharing
2.Extract Using WinRar on PC / Mobile
3. Paste in SD card
4. Plug in the card in LCD
(I have given Name MobileNavigator of the main folder have .EXE file as my city aspire CASCA LCD had default path)
5. Connect your android phone with debugging Usb ON (Just Google how to enable debugging mode in android if you don't know how to enable it)
6. Now you will get two options
......(a) Left ICON for easyconnect via usb debugging (for android screen mirroring)
https://drive.google.com/file/d/181jsT3m5BuLAEQK24ve_sS8Xh7F4KDVb/view?usp=drivesdk
Use this apk and install on the phone for android 8 / 9
.....(b) On right side for Selecting Navigation paths on your SD card for Navigation Software you want to run (For example I have sygic,,,IGO and Navitel in my SD card.......So i can simply toggle between them to switch Navigation app I desire at the moment....without Connecting my SD to PC and copying again and again)
7.
https://www.youtube.com/watch?v=oucZE4G0hwI this is how it is is going to look like
