Doing a little RND out of much of my time. Today I went for an Electrition to get my dim head lights checked up....... Man total frustration. Could not trace the bug even added one his own but that AC Blower wont work now.............. Didnt paid him single penny and went back home traced the wires and connections and bug was gone.
Today i got user manual in detail which tells all electrical wiring systems of my accord. By the way i would also get one for your accord. Take it as gift and explore your car. After reading this i am amazed in 92 they made beast with all features. My car has a control box that dims the clock and other lights if Parking lights are turned on........... amazing...... Has PWM Based Key, Cigeret, ash tray and glove box lights. Superb. Lovin it..............
In Regards to DLC i am working thins out. May be @Xulfiqar may help. What is the difference between ODB2a and ODB2b? i think its pin config only......
I found Pinouts of Similar harness as my ECU.............:FFS TechNet : OBD2a ECU Pin out Schematics :.. Only problem is color codes do not match existing wiring and some other pins such as 1,2,3,4 should have injectors wires but my ECU has only one wire out of these 4 so kind of crappy. Once i figure it out it would be piece of cake inegrating the DLC............ Making it work would be next ...........
@sulemanb in your cluster either a cable would be loose or a screw may not be as tight because the gauge motors are connectors with screws as electrodes which power then from PCB. So they get bad often when you open. As you know These guys do not care about screws coming out vs going in.............. probably he missed something.............. its nothing fancy in cluster..............
