Salam Everyone,
My accord, 1996 engine f18b manual, while engine shuts down suddenly... i mean while moving if i stop at the signal the car would just drop the rpm (sometimes) and would not start no matter how many self (starter) you give... then after sometimes it would start as normal (normally my car starts at half self as is it only petrol driven with 160k on the odo).. this used to happen only sometimes but now daily.. 10 mins the car would drive ok but suddenly the problem would start..
This car is with me for around 20 days and i have driven it for around 300-500 kms.. there is no starting problem in the morning or at any time..
I brought an experienced mechanic yesterday who after detailed checking said that the fuel pump on the fuel tank in the rear is suddenly cutting power randomly.. he said it could be some tracker issue (on which i called the previous owner who replied in negative, as there was none).. the mechanic said an able electrician would check.. he checked everything distributer..current in coils.. radiator water plus gas kit condition.. check engine light also turns on at some occasions... (this may be the speedometer sensor which is not working)...
The mechanic has given two final verdict.. one that it could be some very minor issue and second could go as high as problem with the computer card...
Dear brothers, i am in Karachi and newly shifted here.. looking forward to some sincere advice..
Kashif
