I just had the oil changed. Liqui Moly 5 30 for Rs 4800, ouch. The guy was saying that you could also use total quartz SN grade which is better than the one Honda gives. As per him the honda genuine oil is locally made and the total quartz is imported. Btw they had the drain washer as well so that worked out.
Now have to see if there is any improvement in mileage. Plan on using the Liqui Moly oil from now on. The 8k drain interval should pretty much even out the overall cost, should end up being slightly expensive in the long run, but since it's a better oil, it'll be worth it I suppose.
But Honda used to service the brakes and suspension nut tightening, will need to sort that out from somewhere now.
