Does the transmission not engage or just slip while trying to move?
why is your ABS lamp on?
i have 2006 idsi vario.
my gear would slip and tachometer jumps up and down.then sometimes D starts blinking which is transmission failure.
everyone recommended new gear, but checked sensors and everything was fine after that
Salaams Sir I have Honda city Vario 2005 Yesterday I also come across the same problem as mentioned by you "cvt driven pully speed sensor malfunction"I went to the mechanic here in Sialkot all the three mechanis suggested me that the gear of the car is damaged you have to change your gear with some kabli Gear. When I switched on the car it move a few meters and then later D start blinking. Then for further movement car demands more RPM and gear shifting undergoes jerks. Kindly suggest whether I changed the gear as suggested by the mechanic or tried something else
Brother i have the same issue with my city vario 2005.How was it rectified?
