@ayan_cdkey @pwuser151967054480 @pwuser155064690470 you guys need a time out now. This forum has been badly stained.
You guys want to fight, please continue over the PM feature. We will report your posts. Profanity is unacceptable
one question, regarding engine flush, u suggested a 2 litre mixture if diesel and any heap engine oil? is it safe pouring diesel inside engine? and there are certain flush oils available availble in market ? whether your formula work equally good ?
This is your first and last warning to use decent language. More trash talk will not be tolerated.
This forum has gone insane. Whre r pakwheels moderators who used to BAN users. The above comments were disgracefull and they should be given a proper warning or close an account or two. This forum really helped 7th gen users in keeping their cars in top notch condition but after reading everything above i am amazed that not a single moderator intervened to stop this fight. Admins plz keep a check and balance, would really appreciate that.
Yes it is completely safe to use diesel + cheap engine oil mixture for engine flush if use properly with care.
Can anyone please tell me why my civic 04 is producing light blue smoke on high rpms there is no drop in engine oil level i'm using havoline 20w50. HELP REQUIRED
Blue smoke on high rpms. Oil control rings is the problem.
what are oil control rings ? pistons or pcv?
Get compression test done from a sensible mechanic.
Can you recommend any good sensible mechanic in lahore.
All Motor, Kot Lakhpat Lahore.
Magic motors model town also can do compression test.
the results were 150,140,140,130 are they good or baad
Bad.
165 to 170 is for excellent engine, 150 is okay, 140 works somehow but its near to bad, but 130 is almost ur cylinder giving up.
180-200psi across all cylinders is excellent. My Honda had 200psi across all cylinders even after 20yrs.
i dont know why pressure is low.Points to note:1- Water drips from engine in morning drive of about 4 kms.2- No reduction in engine oil3- only produce smoke when rpm is above 5000
