Hay i want to sale Hondata K-PRO With ECU demand = 105000/- For more information PM me.
The Hondata K-Series Programmable ECU (K-Pro) consists of a hardware modification to any Honda K-Series ECU, plus Windows software which allows you to re-program the ECU and data-log sensors.
Main features:
- KPRO components are contained within the ECU
- USB connection for speed and compatibility
KManager Windows based software for parameter & table editing, calibration uploading and datalogging.
- Many built-in calibrations for common engine combinations
- Built in datalogging to a laptop
- On board datalogging memory (2 MB memory, 10-110 minutes datalogging)
- Adjustment for different sized injectors, with overall fuel trim.
- Configurable for any MAP sensor (to 5 Bar and above)
- TPS based table lookup for ITBs
- Engine protection from over boost and lean protection.
- Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
- Launch control with anti-lag
- Three multi purpose outputs for nitrous control or similar
- Supports lambda tracing from the stock wideband o2
- PWM output for boost control
- Made in the USA
KManager editing software features:
- High and low speed 16 x 20 ignition and fuel tables for correct VTEC tuning
- Injector size fuel trim
- Fuel trim for starting, throttle tip in and individual cylinder trim
- Rev limiter with fuel cut
- Adjustable VTEC window with load and throttle control
- Adjustable idle speed
- MAP sensor type and calibration
- Adjustable boost cut with hot and cold settings
- Closed loop control
- Air temperature compensation
- Fuel and ignition correction based on gear
- Closed loop
- Three general purpose outputs for nitrous control, quad boost control or similar
- On board datalogging trigger conditions
