Tajammal brother, one more question plz. what suppose to be the proportionate size of window of 12*14 ft room. my plot size is 30*60. and the window opens in backyard (Laundry area) of the house which is 6ft wide.
I dont know why in Lahore there are no underground tanks. All houses rely on supply line water and assume water is available 24/7. In Islamabad, CDA does not allow motors directly on supply line.
Because there is no water supply problem in Lahore, i think. Yes for ISB, you are right, UWT is mandatory requirement.
It depends upon as per actual layout and available space. If full walls available then it can be 6 by 4 OR 7 by 5Start windows from 18" above floor and end it at height of 7 ft.. This level shall be same i all house to give it a symmetrical looks. Thanks.
Tajammal brother, Thanks
Tajamul i visited the market and shopkeepers are recommending jet pump for municiple water line. I have found a jet pump of 0.5 hp (enough for my requirement). I just want to know what do you say is it good pump. It has the suction and discharge ability and its a self priming pump.
DearYou can evaluate as per specification sheet. Power requirements seems ok. And if sanitary guy recommends this then pls proceed. Self priming is good option.
HiNeed suggestion for interior house repaint. Previous paint is Berger Enamel (oil based). Lived its life. What would be better now, same enamel or some good emulsion paint over the previous one.Expert opinion please.
Tajammal brother kindly email the tools on ak_khattak@yahoo.com
Sent dear.
Can you please explain the reason behind structure weakening of left like this and how white cement coat will prevent it.
Do you have some sample pics?
If the base of walls is good? Then i would suggest you to go for Matt Enamel
Not exactly but an idea
Assalamoalaikum DearTajmal Bhai,I was searching for some useful tips on house construction. I found your blog very useful. Keep it up. Can you please send me the calculation tool for bricks etc.abraizahmed@gmail.com0333-3660117
Assalamoalaikum Tajmal Bhai,I was searching for some useful tips on house construction. I found your blog very useful. Keep it up. Can you please send me the calculation tool for bricks etc.abraizahmed@gmail.com0333-3660117Thanks
Can you please share procedure for making a hole in a 9 inch wall for exhaust fan in bathroom wall. Currently it has no exhaust and I want to make a hole with minimal disruption
Hi
Guitl,56
Hi Tajjamal84I need your contact number to ask you regarding few suggestions.Its dr nadia.Pls send me your contact at drnadiaf@hotmail.comThanks
