the toyota duet compressor is very common, its a weaker version of the old corolla compressor from the early 2000s - its nothing special. - Lots of scrap parts.
there are tons and tons of other good performing parts - e.g. mazda used diesel kiki compressors in the 1988 929s (big boxy cars) which came from Kuwait - later on in Pakistan I heard that its compressor is fail because japan thandaa ilaqa hai. Ye sanden 505 lagalein, ice cream machine bannjaigi gaari.
no matter the car was a GCC spec with a really solid condenser being cooled by boss grade fans. The facepalm moments were so epic that I cannot start.to tell as I would have hiccups laughing.
The only issue on them was a weak/bad expansion valve after about 10 years - which is easily repaired.
For A/C shops in Pk - they think the compressor is what causes cooling. Ask them about liquid temperature and they would look at you like you have horns on your head.
Nihon compressors in Nissans had no problems anywhere in the world - except Pakistan, The zexel ones used in some later mazda (RX8, Atenza, Axela etc) and some nissans had no issues globally except in Pakistan they suddenly had the "thanda ilaqa syndrome"
