Removing ac thermostat will harm compressor?
hi guys. me have 2006 mehran as well. i wana install ac . usually i use cng as a fuel in winters i hv to use petrol due to cng shortage plz suggest me which setup will be suitable for me . m from lhr
please go through the topic above and it will provide you with the required information.
yes. Car needs AC tripping to ensure no over heating issue. without thermostat compressor will run continuesly which will cause icing issue and will harm compressor as well.
Sir actually car is quite old now but havent ever given me heat up problem. It has 165k on odo meter yet its fan works on orignal thermostate process but sometimes it also not works auto for that i have place a switch in dashboard if fan not works auto.Thats y i am asking about what should do for proper ac workingWill that fan running problem automatically covered during ac installation ?These are some points i wana know
Mehran radiator fan continuously runs with AC on. It will go on auto as soon as compressor trips.
yes keep the fan on auto and let the thermostat valve stay in the cooling the system.
once AC is on, the radiator fan will run continuesly with AC and it should be ok.
Today my electrician suggest me to get double condensor installed in mehran 2015 which according to him will increase colling amazingly like other bigger cars. I ask him that there is no place for 2nd fan however 2nd condensor can be fitted and he said there is no need for 2nd fan.All experts please tell me, whether he is saying correct and should i go with his verdict as i have recently installed denso ac about 2 weeks before and it temprature at vents remain 12 to 12 degree which is higher i think it should be around 7 degree.Thanking in anticipation
I have installed brand denso setup from 3s but colling even in these days is not satisfactory. Technician asked me to add an aditional condenser. As per him mehran has small condenser thats why cooling is not good and because sole big condensor cannot be fitted due to less space therefore 2 condenser should be installed
Since its new one for euro II, i guess it will be multiflow. Right? How multifliw looks like
If facoty fitted system then YES.Otherwise God knows which one USTAAZ installed
I confirmed its multiflow one. Electrician also advised that for best cooling replace evaporator with bigger one. He said that big evaporator is available in markeet for mehran
God know who is saying right.
@xulfi85 how to adjust mehran ac thermostat. Can it be adjust manually? Temprature at vents remain 14 to 17 now a days which is high i think. Please reply
I have ff thermostat. Ehat should be pressure at low side of r134a. Mine is 25 and it goes further down while acceleration. Suzuki 3s said gas is ok
Please tell me correct pressure every electrician says its own
