For how much you got the a/c?
bro kenwood 1820 is kenwood top of the line model with T3 comprcr and very big indoor and outdoor unit with wifi....kenwood 1827 is also good but with T1 comprcr with normal unit size...always buy top of the line model from xyz compamy...
kenwood 1820 is 80 thousand ayz electronics Peshawar
Bhai koi rwp/ISB mein bhi bata do agar kasi ka pas vacuum pump ha....kindly refer a guy...I have bought a kenwood1820 need to get it installed this weekend.
How much did u buy 1820 for?Other option I am considering is Mitsubishi 1.5 ton inverter.
Here is some data based on my research on the specs of different brands that I am considering. All models are heat and cool, Prices are taken from online so actual prices could be lower. Specs are taken from manufacturer spec sheet for the model numbers mentioned. Based on the data, I can conclude the following:
How do you say Panasonic is most efficient?
Because it uses 6.9 amps to deliver 18,000 BTUs of cooling at full power. I plan to run it on solar, so max amperes matters, since I only have a 3KW inverter.
Anyone using pel fit. It claims to have eer rating of 4.0
I have Panasonic, nothing beats its performance this is my personal experience
shakir visited today and daignosed adultered gas and leakage on valves, he said he will check in wall lines or leakages with sme pressure equipments first and then focus on the unit.
Which Panasonic model do you have. Is it the recent one or is it an older unit?
Good work.I am also planning to buy Samsung 1.5 ton DC inverter (Triangular series). Does it have WiFi so that it can be controlled from Android App?
Its cool only or heat & cool??
Ofcourse! i was only asking for my information. If one has the budget, LG and panasonic is best. Samsung is overpriced for cosmetics
Looking at the prices of inverters these days. I am wondering if its worth it to upgrade my current normal Gree 1.5 to inverter hm I mean it will take some time to recover this and have any saving.
How much bill does current AC cost you? Unless you need to buy an AC, there is no reason to upgrade from non-inverter to inverter.
On a site note, Kenwood is around 90k these days, is it really worth it? what are current prices of LG and Panasonic.
Last season we were running 1.5 and 1 Ton (12 to 13 hours a day) along with other household items and we are a bit cautious in a/c usage. So at average it was 18 to 20k.
Brother if you need to upgrade your AC then its worth going for inverter, if your AC is already working fine and not old and you are changing just because of inverter than its not worth it.
You should be able to get kenwood for max 82000, online rates are 85k. I got mine last week for 75k (it was a limited 23rd march offer)
