Brothers - Stop installing 3rd Party HIDs - it not only disturbs the virginity of your car; but also creates problem for the car coming in front of you. live peacefully, drive sensibly and help others to drive safely.
In case if there's some real requirement (not sure where) - one must check the power requirements of HIDs by some DC-AMP meter, then get proper heavy duty cable & relays deployed by educated & experienced technician. make sure the relay helps to reduce heavy cable route (from battery to lights) and there're no 'stupid' joints on the way. Use imported grips where you need to make any join
*** DO NOT FORGET TO DEPLOY FUSE BOX FOR ANY 3RD PARTY ACCESSORIES ***
Kissi ko heavy lights maro gay tou wo dua tou bilkul nae day ga. auk kisi ki baddua may cause 'burnt civic or corolla'
Good luck
