Well for suspension related stuff I have a contact in rwp not lahore as I haven't had to explore on need basis yet
Can you give me his number?
In boxed
Sir are you sure toyota cvtf fe is compatible with jatco7 (cvt in mirage) ?Hows your car doing with it ?Iam going to change it in few hours I"ll be greatfull if you me soonMy option are cvtfe (toyota) or kixx cvtf
Brother not at all. I'm using it after change. More than 10k kms no issue at all AlhamdoLillah
Found this interesting information
http://mirageforum.com/forum/showthread.php/230-Australian-Recall-Mirages-manufactured-prior-to-26th-Jan-2013-(wheel-speed-sensors)
As some may know from above, my Mirages bearing broke, so had new ones installed but since then all the cars sensors have been going crazy. Just learned that there was a Mirage recall in Australia for the same problem, it is caused by a faulty transmission speed sensor. Will get them replaced now, hoping for the best.
How much did u get the bearings for ???
I asked some1 just for you
He quoted Complete Front Hub Pair for 16K & Rear for 10K.
& if u want any sensor from Japan O can try to get it for you
I Need the Part #
You can whatsapp me
Wassalaam
Thanks a lot for asking! I'll IM you for details.
Very nice, what average does it give at 120?
If i stick the rpm 2400-2600 it gives 19/lSpeed varies from 115-120 between this rpmBut when i stick it to exactly 3k the speed stays constant to 130km/h and it only changes due to slopes or height!
Apparently Mitsubishi EK Wagon has the same Air filter as that of Mirage. This local one costs Rs.500-600
Your number for whatsapp?
Hello Pakwheelers, how much should I pay for this Mirage:
12 max
Since its dealer purchase not from auction& model is 2013
Thank you for the reply .
I gave him the offer of 11.50 and he was asking 12.3. We are in the process of negotiation.
I'm sorry this isn't same as what original filter looked like so I finally found that one Denso made in quantity, anyone looking for air filter should look here: https://www.pakwheels.com/accessories/mitsubishi-mirage-nissan-days-air-filter-denso-2271383
[/quote]
also, this looks pretty crappy
I get average of 13-18/litre with extreme traffic during shopping at saddar etc
something wrong with the images perhaps... there should be black touch buttons at the place of keyholes for the KOS operation, do confirm with the seller though!!!I can share my car's snaps so you can be sure.....
