It's around 5 to 5.5. In city and goes up to 7 to 8 on highway.
How can it be that the guage was moving at 104 and now it doesn't. The guage represent the temperature so does other things also interfere with its readings.
Beacause before the temp was not being stable and was. Constantly on the rise. Now the temp is going down when the vehicle is moving.
Before the repair at what temp the guage started moving I mean leaving it's default position.
After 104, around 105 I used to turn off the engine.
Ok.
just an update the compressor died lol.......... screwed up the condensor as well............. but Alhamdulliah got it changed and is working like a charm
Abs motor was making noise and getting stuck so sourced a ABS unit. Will insyal tomorrow and see how good it is
New unit installed but still the issue is there now checkking ALLL the sensors. Bloody hell
Now I have an abs unit for sale lol
Why didn't you make sure it's the unit before purchase
Why do you think I didnt. The abs was making vibrations and giving error after wards.
Because if you had checked it, and yours was faulty, you won't have an abs unit for sale. Nor would you comment that "now looking into All sensors"
The sensors were fine, no electrical issue then we came to the conclusion that the unit malfunctions periodically.
Not my first rodeo bro
So at present, the fault is still at large? And if the abs unit malfunctioned periodically, it still needs replacement, or is it the incorrect readings that make it malfunction?
