Fahad earth one wire of head light to frame, sir the only solution to this is stretch your holder spring much more take out the base connector where bulb points connect take out the spring stretch it more so it become long enough put back along with the connector base here you u go wont feel dim light any more try urself
frkadeel I will send you the bulb no problem at all the only problem is keh bulb Rs. 100 ka hai but courier charges are Rs. 210 total 310/- PKR hojatay hain koshish karain koi aur member bi order kerey takay shipment charges dono per half divide hojaen
Lahore, Ahmad bhai try to go to any whole seller of the bulb tell him you want NARVA S2-12v-35/35W. Maximum 120/ PKR would be the cost else try to gather more members from Lahore city to order this bulb I will send u so that shipment charges distributed equally
Amjad bhai and @isb_rider congratulations luckily aj mai ne holder change kia kyun ke purana holder 125 deluxe ka tha aur wo bohat cheap quality ka tha aj new lainey ke liye gya I asked for 125 deluxe holder from honda dealer usney kaha nahin sir nahin hai khatam hogya I said oho pata nahin dimagh main kia khiyal aya I said CD-100 ka holder dedo usney kaha nahin chalayga I said ap dedo mai ghar le aya Rs. 80/- ka hy CD-100 ka holder aur CG-125 Deluxe ka 100RS ka kher ghar akar light kholi holder purana phainka opened new on bohat achi quality thi CD-100 ke holder ki installed it aur proper agya fit bulb bi bohat acha connect hua alhamdulilah its working tip top
