Does lpg milage depends upon the petrol milage ??? I didnt drive my car on petrol from last 3 to 4 months. Now as cng going to be closed for 4 months. To get good milage on lpg does I need to first tunned it on petrol ??????Also want to knew that is it worthy decision to drive car on lpg @ 130/ kg whereas these days petrol @ 94.40 / ltr.
Dear Expertz,Reply Please........
Janab!i personally found it infeasible, yes it did gave very good average sometimes+smooth ride, but i can't handle all those siyapas i mentioned in my post ----- and the reason i got rid of cng/lpg.
But still if you wanna try, toa tajurba karnay meyn kya harj hai ...........
130/kg here in sargodha.... costing me equal to petrol in gli 06
Sent from my A700 using PW Forums mobile app
Are you using CNG kit or LPG kit?
Lpg price today is 125/kg.One more thing.it's best to keep 1kg gas extra when filling 2kg of lpg In an empty tank cause the car car chokes on full accelerator.Due to low pressure.
Congratulations guys the government has pressed hard to take LPG price way down further
went after a long time to get oil drained n not a single drop came out from kit :obtw there's alot of lpg smell coming from inside n outside of car, from blower as well, though not that much but whenever some1 else sits in they do say so
Sent from my GT-I9500 using PW Forums mobile app
how much price came down? n in isb as well?
^^ which kit are you using? if on cng, what modifications?
I using BRC lpg kit..
Does LPG affect engine adversely?
No it doesn't
So buddies finally got another vender who fills branded SSGC LPG in CNG cylinder so filled 5 kg let's see how far it goes... If it does 100+ then will continue otherwise would have to get back to CNG...
Sent from my QMobile A51 using PW Forums mobile app
@Chauudry9
Bro i have my mehran on CNG. Please suggest me from where u get the conversion done in CNG kit for LPG & what is cost for it . Secondly do inform the place for filling LPG in G-11.Thirdly how much is mileage per KG of LPG.
If Gas is good quality, there will be no oil or less. If Gas quality is low, oil will be there and it ll be black.
There should be no smell, it seems a leakage, better get the kit and pipes checked by mechanic for leakage.
Bhai I'm too much confused, monstly people claim that LPG is beneficial and mostly said no major difference. My case is same as yours, I have Mehran VXR 2006, currently getting 13 in City and 15 on highway, what will be the expense ? some trustable person recommend me to use LPG electronic kit (3500 Rs for new) and 1500 extra charges, should I take risk? Currently I have Landi Ranzo CNG kit with Faber 40L cylinder....plz reply ASAP
I have almost same query as mentioned above I own alto 2007 which is ofcourse is fuel guzzler. Should I go for LPG. Other day I went for LPG but LPG vendor at G-9 told me that it will freeze. I got confused so I did nt go for it.
Sent from wirless comm gadget
I thing I noticed, people claimed 18-20-22 averages and considering it very good on LPG, my question is that If u calculate the Price per Km then there is less difference, for example if my car done 15 kmpl on patrol and patrol price is 95 rupee and same LPG giving me 20.5 KM per KG with 130 Rs per kg then there is no difference in cost.
Get your car tuned onece but proper with adjustment.my engine was overhauled Two months ago.then comes the lpg filler and the quality of lpg.check the vendor.Also don't floor the accelerator pedal.drive around 60 to 80km/hr. If you fill an empty tank then the gas pressure in the tank will be low and you will get good response for the first 1kg but then you keep the pedal as light as possible cause the last 1k will be a little bit choking so always keep 1kg extra in your tank meaning if you plan for a 4kg fill for your trip then fill 5kg when filling an empty tank.
