What is the disadvantage u guys faced so far in LPG fueled cars... Any demage on Valves?? Apart from freezing issue in winters???
Sent from Mars
If I filled from hascol so ,it would require new nozel etc ?? Service cylinder ?
I recommend don't go to hescol...they r enjoying monopoly...Find some local vendor...
No issues everything works fine... Even better than petrol...
Do u knw any place in karachi ?
I know one at Sachal Goth...I fill 10 kg which is enough for 15 days...
How they fill ?? From normal cng nozel ??
Yes...Dear lets find from where can we purchase Cng filling nozzel...I want to purchase one afterwards can ask anyone to fill in lpg in the cng setup...Can u contact and find out...?
do not use lpg with CNG kit however u can use the same cylinder..i used lpg with cng kit and it literally destroyed my kit..(leaked diaphragms) eventually leading to replacement with Lpg kit..so i would suggest to change the cng kit with lpg kit..it cost just 3000 rupees from lytton road lahore..it works with the same switch and wiring as that of the cng kit..and gives better mileage also..
What u change ? cylinder ?? exchange or purchase separately for Rs 3000
from which type of shop u filled from ? normal taxi waly jin se Bharwate hen cylinder nikal kar ?
i purchased LPG kit for rupees 3000 including fitting with the existing cng cylinder..its plug n play..the cng kit is lying in my store..
@ali454 which car u r using this kit into and what mileage u r getting. Did u felt any difference in the drive of both kits....
im using it in my carby cultus..mileage is good around 20 21 per kg with 50% AC in lahore traffic..the advantages i felt while using this kit are1. No drop in rpm when there is low pressure left in the cylinder..2.The drain nut is very easy to open and drain oil.It can be opened by hand whereas with cng kit i had to use elky..rest of the stuff is same..i
@ali454 thanx for the info. BTW where have u got the conversion done from...
there must be many brands of LPG kits in the market. Can you post a picture of yours? Does it have a label on it?
lytton road mozang chungi lahore
local made and irani both are available..some are selling local kits claiming to be irani..will post a pic soon.
Yes... Both r available... Irani Kit has better built quality and local is poor in built quality... Dont know abt workability though...
Price for irani LPG kit is 3000-3200And price for Local LPG kit is 800
