Some good engines which i have short listed for my car, you can consider them too.
1AZ-FSE
Displacement: 1998
Engine model: 1AZ-FSE (D-4)
Max.power (Net), kw(PS)/rpm: 152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 20.4 kg*m (200.06 N*m) / 4000 rpm
Power density: 10.39
Fuel system D-4 (inside the tube directly fuel injector)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio: 9.8
Bore, mm 86
Stroke, mm 86
Fuel consumption at 10-15 modes, l/100km 7.9 (in 1580kg vehicle)
IG-FE
isplacement, cc 1988
Engine model 1G-FE
Max.power (Net), kw(PS)/rpm 160 ps (117.68 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m)/4400 rpm
Power density 9
Engine information VVT-i
Fuel system EFI (electronic fuel injection)
Turbocharger No
LEV system (Low emission vehicle) No
Compression ratio 10
Bore, mm 75
Stroke, mm 75
Fuel consumption at 10-15 modes, l/100km 9.6
4S-FE
Displacement, cc 1838
Engine model 4S-FE
Max.power (Net), kw(PS)/rpm 120 ps (88.26 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.5 kg*m (161.81 N*m) / 4600 rpm
Power density 10.5
Turbocharger No
Compression ratio 9.5
Bore, mm 82.5
Stroke, mm 86
Fuel consumption at 10-15 modes, l/100km 8.1
3S-FE
Displacement, cc 1998
Engine model 3S-FE
Max.power (Net), kw(PS)/rpm 135 ps (99.29 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 18.5 kg*m (181.42 N*m) / 4400 rpm
Power density 10.3
Engine type Serial 4 cylinder DOHC16 valve
Fuel system EFI (electronic fuel injection) (Ci . (central injection)
Turbocharger No
Compression ratio
Bore, mm 86
Stroke, mm 86
3Y-EU
Engine model 3Y-EU
Max.power (Net), kw(PS)/rpm 97 ps (71.34 kw) / 4800 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.3 kg*m (159.85 N*m) / 3800 rpm
Power density 17.42
Turbocharger No
Compression ratio 8.8
Bore, mm 86
Stroke, mm 86
Fuel consumption at 10-15 modes, l/100km 12.3
