I am using liqui moly for last 3 years in honda 125 2014 model.
Due to not checking, oil was used too much and piston got bad. Changed piston. Did running. Again at 45000 km
So had to change oil at 500 km interval and didnt want to spend or waste liqui moly. SO used honda oil. After 500 used honda oil again. And to check engine speed n all. I traveled to lahore from multna on bike. To my surprise. Seals got broke before sahiwal. I was so much regretting my decision to not go for liquimoly. Checked oil. Found half of it has been leaked. Because till sahiwal. I was riding at top speed all the way.
Bought 700 ml normal oil bottle and filled the half.
Now i know why liquimoly is good oil. It doesnt leak no matter how hot it gets.
Honda change interval is 1000 km. i thought liqui moly is good oil so changed it at 1500 km for almsot a year. Once at 2500 too. But later i found out that if company says 1000 then u have to change it at 1000 no matter u put highest quality synthetic oil. But i will do some reaearch further. So i avoid buying expensive oils in liquimoly list.
Find whats specificity and viscosity of oil is recommended for honda cbf. Buy the same viscosity oil from liqui moly and you will be fine.
And because it doesnt get slim and hold its viscosity, clutch remains good all the time, sound doesnt change much. Gets cool fast and not much heat coming out of engine. Cool also gives us good mileage.
Mine giving 55 kmpl at 60 kmph constant speed. And 31kmpl at full throttle.
Good luck. Hope it helps.
