But my sincere advice to you is to either install these 185/65 R14 on your oem steel wheels or get yourself cultus oem alloys or any Japanese car 14" alloys.
Because these Chinese rims have very wide cenral bore so that they can be installed in any 4 nut hub.
However OEM rims are Hubcentric ie rims will sit on your car hub this makes them stable at high speeds above 130km/h. Thats why no matter how good wheel balancing you do on these Chinese rims they will vibrate above 140km/h.
Note that :- 1.Suzuki , 2.Toyota , 3.Daihatsu all have hubs that support Central Bore 54.1mm in diameter.
Any used OEM 14" rims of these manufacturers will fit your Car (avoid Honda rims)
While Honda Hubs need rims that have Central Bore 56.1mm.
Thus, you cannot install Toyota rims on honda even if they have same PCD ie distribution of nuts.But you can install OEM Honda rims on Toyota because Honda OEM rims have Central Bore of 56.1 which is wider than Toyota 54.1, but the difference of 2mm makes honda rim unstable on toyota or Suzuki.
Also these Chinese wheels are casted , while oem wheels are carved which makes them sold as compared to these Chinese wheels.
Thats why you feel more vibrations and impact on cat eyes and cracked roads in car installed with Chinese alloys.
