Kisi ko pta he k nissan dayz me fuel pump relay kis jga per hoti he?
Does anyone know from where i can buy Nissan Dayz brake oil container cap in Lahore?
Need good mechanic for Nissan Dayz in Karachi
This white thunder light keeps on appearing when i apply brakes or sometimes when i lift up my foot from accelerator.... i have recently installed a new dry battery
for all the people who are getting low mileage I wanted to ask which option is better...replace the catalytic converter of get it cleaned?
If one can afford, then replacing Catalytic Converter with brand new one is the best solution (I am saying new, not used one).
Otherwise, get the old one properly cleaned / serviced.
Aoa Can anyone plz guide where to buy mass air flow sensor for nissan dayz?
please send your contact number
U0112 ASSIST BATTERY CAN TIMEOUT eco idle off and dashboard camera not work how can resolve
Did you find mechanic rohail
Help Required
my nissan dayz 2015 360 camera is not working on the rear view mirror... can anyone pls advise me what to do? Is there any method to reset the system. when i pull down the car gear to "R" nothing appears on either the rear view mirror or the entertainment screen.
Hi Guys
I bought Nissan Dayz 2015 .I did engine tune up also but, vibration comes when I press break. When in in traffic also same. Please give a solution.
Thank youUmesh
Aoa send his number too
My Nissan Dayz 2015 recently clocked 40k km and I want to change CVT oil, Please suggest best CVT oil for it.
Can anyone post picture of Nissan Dayz's Brake Oil reservoir cap from both sides including part number?Thanks.
Looking to buy Nissan dayz higway star.How is it?Spare parts are easily available in karachi?Cheap?How frequently does it require engine check up?will you recommend it to buy against city same model that is 2014?
Mery nissan dayz highway star k front walay shocker kharab ho gae hainAchey or munasib qeemat main kaha se milengy?
Wrench sign means to reset the milage record after every oil change..it normally resets to 0km till 3200km driven on oil change .
I'm curious what this yellow key sign means can you help?
Is this group alive? Nissan dayz turbo is 4wd should i remove the 4wd and make it to 2wd to make average better
