it does - if the engine design allows it, toyota 0w20 is about as heavy as a 30 hot oil when at operating temperature and because the viscosity spread is pretty low the oil is pretty robust itself.
I live in Houston, TX - its like sibbi in the summer (but with humidity) - Fords usually run cheap dino 5w20 engine lube - and have no problems at all.
