Thank you for the detailed reply, and good luck!
The Turbo Unit not allowing to adjust the engine with its basic set up.
some side work also done .
Fly wheel Bearings size difference.
How can you do it with plate? I thougjt it is necessary in such cases and no other way
i have not used any Plate/adopter plate as i do not like to increase and weld the length of Main shaft which rests in Clutch Plate and also the clutch adjustments after adding adopter plate is not up to the mark.
clutch plate alligned
the clutch plate allignment tool.
Time to Mate them on Ground
Finally the Update is on air now...very excellent work and i personally know the hard work you put on your ride is superb...just waiting for the next upcoming trip on her...i have also hear that you have upgraded the interior as well:)
Brilliant work
some really nice efforts being put into this ride. anxiously waiting for end results.
Thanks and more update coming soon
Finally The Pajero Gear Box Mated with The Toyota Motor Sucessfully
If gear can be maited to engine without plate when why do people mate them with plates?
Its totally depend on the engine choice you want to put if the bell housing is of the same size. Self starter is on the same side, than you have many options.
Now the Turbo Selection..Ct-9, Ct-12
Finally Decided To Install CT-9
