@joinami.brother you are doing great job.love each and every step of your restoration.best of luck
Sent from my GT-S5830 using Tapatalk 2
Saqib Bhai manual Fan will be my Last ever Resort as i simply do not like manual fans as in heavy water they behave very bad:(:( But still strickly following the fan behavior .and busy in adding intercooler to the engine.
thanks Armghan bro . Actually as all work is done at home by ourselves with out a single bolt touched by any mechanic thats why you will see the cleanliness. by the way it was nice meeting you on Soon Valley trip .
best Regards
thanks Brother
Very interesting project. I've seen each and every step of the swap and its impressive. Bravo!!!
Sent from my A10 using PW Forums mobile app
Going very well! I have recently developed a lot of interest in these Pajeros. Very well done!
Sent from the Mars using Curiosity's onboard communications system.
you are going in the right direction now.
damni remember (in my school days) while driving one of these, had to look at the watch and wait till it used to hit 100km/hr
good way to put an end to that! very neatly done!
yes this is the reason behind all this swap.
Same here best of luck
Inter Cooler Sub-Assemblies lined up Before Installation
The Inter cooler fan
The Inter cooler Fitting Required Some Custom Made Brackets to Fabricate .
the front Inter cooler Mount Plate ..........Each bolt/nut is selected keeping in mind the size, shape , color and strength ,
Inter Cooler Mounting and coupling In progress
The Engine bay after Installation of inter cooler.
Zabardast ....... Waiting for more update
The Engine Bay
Excellent result .
Excellent job done ma sha Allah, have to meet and salute you both.
