My mini is not shifting into 4th gare, even after 100+ kph, model 09, 15 important, urgent reply needed
Check if OD (over drive) button is working. Its electronic toggle button, so get it checked if its making the toggle correctly and signal is going to gear computer. "OD OFF" light should come on in component panel at one state.
Once you are sure OD button is working, you can look for other issues, gear computer diagnostic, physical gearbox checkup.
Hope it helps.
The OD OFF light doesn't on, on the speedometer,,, since I bought mini. But I think that the 4th gare is on another side & od on another,,,,
In Pajero Mini and many cars OD is 4th gear. When OD is OFF, it will shift to 3rd gear max. This is mostly useful when going downhill and need gear assistance in breaking or going uphill when you don't want the car to change gears too much, and it gives needed power.
When troubleshooting, start with the easiest part to diagnose, then move to more complex parts. Since you already mention the OD light doesn't turn on, you should start from there.
So, can you tell me that without od & not shifting into 4th gare,, mini gets 110+ kph ???
Well, the initial models came with 3 gears forward, and the speedo dial still had 140km/h max speed. So, sure you'd simply rev it past 7k RPM and you'll touch 110 speed.
No,,, its touching 5k rpm,, & goes on 100-110kph,,, without od working & not in 4th gare,, model 2009,, 15, imp
Then 4th gear is working. Get the OD component panel bulb replaced, might be blown off.
I have manual version, on 5th gear with 5k RPM it gets to 100km/h speed, yours is doing it in 4th, you should be happy with it.
i Have 1995 mini pajero manual turbo.recently my RPM meter fuel, temp gauge stopped working. with this all warning lights which lights on startup also not lighting??what should be problem?any fuse or wire?anybody who can help?
It is a wiring issue, probably a fuse is blown or 12V power is not going to the dash meters.
Check this first,
And if problem is still there, you can take out the whole speedo meter and component panel out, just few screws, and check for its connectors. There are two of them. And they can get a bit rusty.
I did same in my Pajero Mini couple of years back, and used nail polish remover damped cloth to rub out accumulated dust and rust. Working perfectly to date.
Thanks to all.Problem solvedGot checked by electrician.One grip was lose.Make it tight and everything was working.
Assalamualaikum
Can anyone suggest me a mini Pajero mechanic in Lahore city
Kindly recommend radiator coolant for mini pajero
LiquiMoly Coolant Part # 6934....2L mixed with 2L water. I found this to be better than Toyota Long Life Coolant
Can somebody send me photo of correct vacuum piping as shown in circle?
Are you having some issues with the car or just curious about vacuum lines ?
The 02 straights long pipes (in the bottom of the red circle) seem OK. For the other pipes, can you post pictures taken exactly from top ?
This one is the actual picture. One pipe is broken.But i m not sure about others.
Anyone plz share his vacuum piping pic for reference and repair.
