However I do need help with 1 issue I am facing with my car,
its a 3.0 V6 6g72 12 valve married to an Automatic transmission.
when idling, the temperature starts to go up and then above the halfway mark with Airconditioning, NO issues what so ever if the car is beign driven, even at low speeds, high speeds is no issue at all.
here is what I have tried so far.
1- replaced clutch, then refilled with silicone oil. the fan is pretty much engaged now.
2- inspected the water pump to be workign fine.
3- serviced the radiator thoroughly.
4- inspected the condensor , it is not blocked, and it comes with 1 electric fan, which is btw working when AC is on.
5- the head bolts are tight.
6- the CAT is not chowked. not even partially blocked.
7- The car does not consume oil, may be just 300 to 500 ml for 2500 kms, which is not much.
8- checked the gas charging, it is not over charged, however my AC guy did fill a little bit of 134a, in an r12 system.
9- i have also changed the fan blades with a different design which has more air flow.
ideas needed, but please go through the above list before you give your ideas. what have i missed.
