4WD
A340H
4.5 liters (4.8 US qts. 4.0 Imp. qts)
A340F
2.0 liters (2.1 US qts, 1.8 Imp. qts)
(d) Start the engine and shift the selector into all positions from ”P” through ”L” and then shift into ”P”.
(e) A340 H :
Shift the transfer lever position: H2–H4–L4 and L4 –H4–H2.
(f) With the engine idling, check the fluid level.
Add fluid up to the cool level on the dipstick.
(g) Check that the fluid level is in the ”HOT” range at the normal operating temperature (70 – 80* C or 158 – 176° F) and add as necessary.
drain the ATF fluid and refill the same & top up, do the procedure above please - Dexron T-IV fluid .
