Bhai, on speed breakers etc, front suspension se chuu chuu type koi sound aati h after sometime
And yes it is 100% true, some are already facing some will later
2 issues, 1st suspension noise (above), second doors
There are one or two doors, in every unit, that needs to be closed with force
Otherwise there is no other major issue reported till now
If you are going for vxl or ags, just keep in mind both issues, that's it
